Mark44
Katie's Boss
- 100% one place
There is no big deal it’s just a different ways of doing it some look for better and different ways to improve on something some don't.
Mark44
Mark44
Mark44
the pressure of applying the tubbies will seal the screw holes... I actually had epoxy drip into the hull through the screw holes w/ the screws in there... that's a crap load of pressure and one hell of a solid install...
follow my instructions on how to put them on and I will guarentee that they will be on for life... I have taken some brutal landings on my ski and not even the slightest break anywhere
my method of install is an improvement over Blowsions instuctions
once again... clueless
I always use Epoxy and filler, then screw (larger than the Blowsion supplied screws) & counter sink the screws, fill over w/ epoxy & filler then glass them on and sand forever. I use a right angle grinder to remove screws inside the hull. Smoother look and stronger too. I would use a chissel if the screws were smaller then clean up w/ right angle grinder. Its more work, but this kinda coin and this big of a mod is worth the extra time and effort to ME. Deffinateley a winter project for me as I will be in the garage in winter anyways.
yea well he needs to get on the water asap so we did it in a few hrs..they might not be as pretty but are plenty strong..one advantage i can see using the glue instead of epoxy is that the glue is somewhat flexable so when they take a hit they have some play instead of cracking like epoxy can..either way..i think the panheads look good..plus they grab alot better..(courser thread and a bigger dia)
Agreed, and if he is not sure he completeley likes them this would be easier to remove. As far as the epoxy cracking, I use as little as need be then use glass to secure them more than anything else, the glass should flex w/ the hull (or so we hope) so far so good. You know what your doing bro, this aint ur 1st tubby party!!!!!!!!!!!!!! Glue em and ROLL w/ IT!!!!!
