I'd get a good drypipe for it.
I would guess that most people if they had the option would run a 62T case with duel carbs. If you wanted to run a good low-end setup get the 61x case with a single carb. The 62T case will add a few mph but is not as forgiving. The 61x case is very forgiving and a 62T cylinder is very meaty put them together and you have a very strong motor.
did you just make this up?
just to let you guys know group k is working 62t cylinders bored out to 89mm
have you got more info on that?
or did you hear it from a guy that knows a guy, whos sister's uncle's friend had a 89mm engine?
The cases need to be bored up slightly to accept the larger sleeves.
if you have an all 61x set up and want to stay single carb then stay with a 61x case. it'll cost $500 in just the case and manifold to upgrade to 62t cases.
