this is confusing . . . .
there is one cooling line going into the head.
there is a small ~1/8 inch nipple capped off on the front of the head.
there are no cooling lines coming off the head.
the water flows into the head, through the holes in the head gasket to around the cylinders and then out with the exhaust
So there is NO cooling line coming out of the head, either to the pipe or the pisser
Stock, there is a little line going from the head to the exhaust but it is capped off when a a/m pipe is installed.
I thought it might be a good idea to add a pisser from this outlet to throw heat overboard from the front of the motor.
So when I install this head, do I just cap off the from outlet (like my stock)
or should I add another pisser, maybe with flow restriction?
