CarFanatic
Fiberglassing Newb
- Cincinnati, OH
ok, my stock 99 boat is soon to be no more. As some of you might have read in my other post, I'm keeping my stock hull for now, and going to build it up. Right now I have xmetal steering and bars, and just ordered footholds and turf. Wamilton also sent me out a scupper which I don't want, so if anyone wants it I'll be selling that. This is what I want to do over the winter. I hope to install the holds soon to try them out before season is over.
What I'd like to do
1.Freestyle hood and nose peice - suggestions? Id like one that I can use my stock pole and blowsion spring.. I'm just used to it and its cut down already, and not broken.
2.Trim system
3. worx 201
4. Prop - I have no idea which one will work with my set up
5. pump cone
6. nozzel bore - unless trim system comes with bored nozzel?
7. Motor build up - this one I need suggestions. Id like as much power as I can get reliably with out going to the extreem.
My guess is B pipe (difference between mod and limited??)
ADA Head
MSD enhancer
Porting maybe (guess I need to talk to lehr or one of the engine guys)
8.Dual cooling since everything will be out.
are front exhaust worth adding like xmetal??
Thats all I thought off... I'm puttin it to the experts!
What I'd like to do
2.Trim system
3. worx 201
5. pump cone
ADA Head
MSD enhancer
