need to confirm the changes to the 2008 superjet for the wiki page
onesojourner
I use a thumb throttle.
springfield, mo
I need to confirm some stuff so I can update the wikipedia article.
Hull has integral sponsons, is narrower in the rear, and has deeper strakes.
50 mm setback Intake grate, rideplate, and pump
Pump has stainless impeller (???)
anything I am missing?
2008 superjet changes
You forgot to mention the Training Wheels installed on the bottom for " Increased stability for beginner and intermediate riders" This was directly from the Yamaha website. Oh I forgot they are called sponsons my bad.
Kaveman
Born in USA(not Kenya)
The pump inlet is like a blaster without the wasted space at the front that the rn and sn have. H-pole is -50mm. Lower steering cable end is changed. Comes with a trim ring in a fixed (currently) non-adjustable position. Oh yeah, the tray mounted crack washer. On the demo unit the impeller was a brushed stainless impeller.
The SuperJet 144mm Hyper-Flow jet pump propulsion system : The new three-blade stainless steel progressive pitch impeller is designed to maximize water flow for high performance. The SuperJet pump configuration provides excellent hook-up and smooth acceleration.
The Yamaha site says the impeller is aluminum. Here's the specs:
Starting at $6,699
Engine Type 2-Cylinder, 2-Stroke
Bore/Stroke 81mm x 68mm
Displacement 701cc
Fuel Regular Unleaded
Type of Intake Reed Valve
Type of Scavenging Loop-Charged
Type of Exhaust Wet
Type of Lubrication Pre-Mixed Oil and Gas
Mixing Ratio 50:1
Cooling Water
Starting Electric
Ignition Analog
Compression Ratio 7.2:1
Carburetor/Injection (2) Mikuni Super BN 38
Spark Advance 6°
Ignition Timing 15° BTDC - 21° BTDC
Spark Plug NGK B7HS/BR7HS
Pump 144mm Axial Flow
Transmission Direct Drive From Engine
Impeller 3-Blade, Aluminum (13/16 pitch)
Length 88.2” (2.24m)
Width 26.8” (.68m)
Height 26” (.66m)
Dry Weight 291 lb (132 kg)
Fuel Capacity 4.8 gal (18 L)
Reserve Fuel Capacity 1.45 gal (5.5 L)
Vehicle Capacity 1 person
Hull Material SMC (Sheet Molded Compound)
Warranty 1 year limited warranty
Color Atomic Blue
vitaly
Анархия - мать порядка!
NY/NJ
Starting at $6,699
Displacement 701cc
Type of Exhaust Wet
Mixing Ratio 50:1
Cooling Water
Starting Electric
Ignition Analog
Spark Advance 6°
Width 26.8” (.68m)
Height 26” (.66m)
Color Atomic Blue
I hope the Yamaha USA webmaster is simply one lazy bitch who cut and pasted the specs from the previous years and missed the important thinks to update.
