w-nut
x2 nut
- christchurch new zealand
im running a set off duel keihins off a sxi on my 750 x2 and have a wee problem starting/takeing off .
the ski starts fine no problems and idles but when you get on and give it some gas it just dies like it has no fuel getting thro . if you blip the throttle and get thro the blah blah bit it seems to get the fuel pressure back and run great . im running the jetting off the fpp web site in the carbs except for the pop off which i havent check as i dont have a pump at the moment . this only happens when the ski has been sitting for about 5mins or longer and you go to ride again . its fine when you stop it and then start again right away .
if i lower the pop off will this help or am i way off base and have another problem
any advice would be great thanks
