wrong fiberglass?
chrisdoc0608
insulting
rocky mount, nc
:pat: i didnt think abt this till now, but i ordered all the supplies for footholds from us composites, and the fiber glass i ordered was this
Tightly woven cloth in a smooth 4 harness satin weave. Tight pattern achieves a good strength to weight ratio for lightweight applications.
3oz E Glass
Style 120
4HS Satin Weave
Thickness: 0.0046"
Cat No.
Description
Price / Yard
FG-C0338
38" Width
Same
1 to 9 Yd
$6.75
Same
10 to 24 Yd
6.45
Same
25 or More Yd
6.15
FG-C0338R
Roll (125yd)
4.98/Yard
was that the wrong type? if it is i guess i can just go buy some from homedepot or lowes.
Mark44
Katie's Boss
100% one place
Just to thin, I use 10oz. cloth so I can cut down on how many layers I have to apply. You will be there for days laying 3 and 4 oz. cloth but it will work.
Mark44
Mark44
Katie's Boss
100% one place
I use 10 oz. and it should only take you a few hours to lay a few layers over your holds. Most of the time is spent waiting on the epoxy to turn green.
Mark44
chrisdoc0608
insulting
rocky mount, nc
oh ok, i know there are 1million threads, but while on the topic, if i can get some thicker mat i should just layer it, let it dry, then layer again, dry, then one more time?
thegoldenboy
RN Surgery... soon
Toronto
1)brush epoxy onto foothold/topdeck, generously but don't let it run and look like crap
2)lay glass layer over top
3)brush on more epoxy overtop (now both sides of cloth are saturated)
4)lay second layer overtop of first layer (back will instantly saturate)
5)more epoxy overtop of layer to wet outside.
You want to put on enough to fader away any white spots (dry spots) but don't slop it on like an idiot and let it run all over the place.
just pay attention, you'll see how much is enough. If you have a big layer ontop of the glass that dries and it looks like a fossil, you probably used too much. if there is white patches you didn't use enough.
gj_fx1
X-H2
you can put down a bunch of layers all at once. Just watch on vertical surfaces that it doesn't sag on you.
