hey can you run a rn pole on a sn sj and if so what bracket do you have to use.
thanks sean
thanks sean
ok thanks well i just want to run a rn pole on the sn and was jw what bracket you had to use sn/rn.
hey borg..
did u buy that from the guys in NH.
i rememeber seeing that ski in action .
Just bolted my FX1 pole onto the Square this weekend with an XMW Roundnose bracket.
What rubber bump stop?
I ground the stops on the bracket a bit, and I ground the bottom of the pole a bit. Now I get full travel.
The bottom of the pole I believe there is a rubber piece that limits the travel I thought?
Doug
Not on the pole, and not on the XMW bracket.
Btw, when I say full travel, I mean about 80 degrees up.
About how many estimated degrees of travel from the resting position would you say the pole moves when mounting a stock round nose bracket and stock round nose pole to a square hull that have not been modified what so ever?
I have a stock round bracket, and will have my stock round pole off my ski soon, and am thinking about doing this conversion.
