WaveDemon
Not Dead - Notable Member
- Hell, Florida
with the help of #.0 and Tom21 We've modified my raider trim setup to throw almost 30 degrees. With the 2 brake levers we had at the shop we were able to pull a cable ½” and 5/8ths” neither were enough pull to pull the raider nozzle to full up trim even with the bolt as low as possible on the lever of the trim ring. The bolt is in the same place as Darrins build:
We came up with the idea of using large fender washers around the bolt to increase the throw. I’ve also thought about using the throttle wheel from a carb on the bolt. What do you guys think? What is the best way to get full throw?
