new RRP steering system
20+hp over a B pipe already exsists, don't quote me on exact #'s here but from what i remember, I had seen a dyno charts on FPP's web page quite a while ago where a superstock engine with a "B" mod pipe was producing around 115? and I have seen advertised/and heard from a super reliable source that the R&D dry & wet pipes on a superstock engine are producing 140+..I have tried a great, great many pipes and the R&D exhaust systems make more power than anything I have ever tested, puts the "B"(with any chamber) to shame but they are a bit hard to keep up and running in a freestyle ski...just my 2 cents on the pipe subject...:brap:
if that's the case then why aren't more people running thr R&D pipe?
B-pipe puts the power down low! It wont make as much power up top as most other pipes, but for freestyle you want bottom end hit, and reliabilty....
I just wonder were this EME pipe puts the extra 20hp? I relize every motor will be different, but if this pipe puts more power down across the entire RPM range...then that is freggin awsome! And I want to try one :biggrin:
Are they going to be available any time soon?
THRUST
ThrustInnovations.com
look how heavy the cast piece is on the b pipe . they are about the same in weight though . From what i have felt maybe malones is a little lighter. keep in mind you will also be using a small gas tank a resonator chamber in stead of the waterbox as well .so additional weight savings there .
