Foot Straps???
Mark Gomez
is where the surf is
Fullerton, CA
Yes its just a different riding style more ideal for surf riding. The godfather himself Joe Kenny rode his like that with two straps for lead and rear foot in surf stance. IMO enough said haha
its personal preference
Mark Gomez
Fullerton, CA
True but dont be like me with mine and use Stainless steel wood screws without Silicone in rush to go ride next morning.
Holes in foam area=foam saturation=heavy ski=bad...
amemoryoncelost
X2/SNsj
tacoma, wa
Are there any good write ups on how to install the straps? It seems like some drilling is gonna need to happen... I'm on an X2, but seems like the same regardless..
Mark Gomez
Fullerton, CA
the x2 i believe is drilling im not sure though but for stand up trays some one posted one called Footstraps recently i think in either this section or Freestyle/freeride
JetPilot
'07 SJ xXx
there is a good thread about how to install foot straps without drilling into your ski. I used this technique and it works well. Most of the riders use the straps for surf riding, having one in front of the tray and one near the rear. I personally prefer having the straps serve the same purpose as footwells or holds and so I put mine side by side near the rear of the ski.
the thread is in tech faq, use the search forum tool and type in, "dakine install". i believe Michael has the thread listed from yamaslut's build up.
straps are great....do a search for the yamaslut acorn nut mod
basically a washer welded to an acorn nut..then epoxied into the tray to make an insert...cover with turf, bolt on straps
Peter123
C-Note
Houston, TX
I'm NEW NEW NEW to this, so don't make too much fun of me.
As I've been riding my ski on the lake, I've found that I much prefer goofy foot surf stance. It feels more comfortable to me and more stable in the chop.
My question is, do I even need footholds if I were to install straps?
W
wydopen
NOPE...unless you like you foot in the same position as it would be in a footwell but in a strap.(farther out than the gunwhales allow)..you can notch out the side of the tray so you toes can go into the side of the gunwhale...footwells are for flatwater and straps for surf...although i do love the way you can RAIL corners with straps once you get used to not switching your stance...doing tricks in the surf in the footwells looks lame imo
Superjetqueen
ISJWTA MEMBER #6
Holts Summit, MO
That is very interesting....good info...:biggthumpup:
JetPilot
'07 SJ xXx
not to mention footholds($75) + new turf($105) + hours of :banghead:($priceless) = lots of time and $money. compared to washers and acorn nuts($8) + straps($12) + 30minutes = :hail:Straps:Banane01::Banane01::Banane01:
wolf
No Holds Barred
Sacramento, CA
Y'all sure you mean acorn nuts? Not sure what the point of using that style of nut would be.
SJQ, I know you know I wanna...:biggrin:
JetPilot
'07 SJ xXx
the acorn nut allows you to weld it to the washer without seeping molten hot metal into the threads of the nut and it also stops the bolt once it has reached maximum depth so you don't keep tightening it into your boat.
now you know... :biggthumpup:
