how to hang a superjet?? questions inside.
xxx2
Reply hazy, try again.
I've never had any problems, I hang it up for the winter months, just take your time and hoist it slowly (I have a winch mouted). The coupler helps support the weight some I suppose and It is an X-2 (top right).......Forgot to mention I don't hook to the boweye, I Have a SS D-ring below it with a Pretty beefy backing plate.
W
wydopen
you dont ride during the winter???????
StandupWI
Sinking with the bilge on
Milwaukee, WI
Personally I think that if it was only for a day or two the mounts should be fine, but I am by no means an expert. Also if you say you are taking out the gas tank isn't it almost required that you take out the motor or at least unbolt it making it only a step or two more to pull it out. Really as somebody else said it isn't much a hassle to take out the motor. But, if you are cramped on time I think you should be okay.
jeepmark4x4
Backflip, weeee
Marietta, GA.
hehe, I was doing my home made footholds and put it up on its nose....as long as the weight is sitting on the ground you shouldnt have a problem
By the way..SHONUFF, If we are ever at the same ride I'm gonna be really disappointed if you don't look like your avatar.
I used to hang my SJ from the bow eye for a few weeks every winter to let the foam drain. There is no reason to drain the fuel or do anything the ski will be fine. And about motor mounts I would rather have the failure in the garage than while you are at the lake so you don't have to be towed back in and fix all the other things that were torn up with failure.
I think his hair might be a bit longer than his avatar..... but he looks so close to that you cant miss him....
But when you see him you won't forget that face..... it might haunt you if you don't sleep good...
