6'4" here too...
I was thinking about just running the shortened turn plate, and 0degree straight bar...
im running minus 6 pole and about to go another -2 turnplate from WD
edit: oh yea and im 6'2"
I don't think height matters. long arms = long legs. you can't touch your toes any better when you are taller.
I'm 6'4" and have about -6 or -7 total, I think me taking off 4" bon the bottom of my pole was a little much, kinda made the curve that the pole has too far forward. In retrospect I think I would have tried shortening some at the top too.
(someone correct me if it's a bad idea) Oh, i have the RN pole on a square, so the lines might be different.
I can put my palms flat on the floor with my legs straight.I don't think height matters. long arms = long legs. you can't touch your toes any better when you are taller.
So if I need a -4" pole, should I take 2" from each side? I already have 0* bars.
EDIT:
What offset plates are you guys running?
not a stock pole tho? whats the most you can go on a stock pole without the pole looking all funky and retarted? oh yea dont you have to set up steering after you shorten the pole i didnt even think about that
^^^^ Do your bars hit your diablo hood at full turn with the pole down?
