I like 4 degrees too.
Also UMI just redesigned there steering to use a castle nut and cotter pin so it can't come loose. I have the new UMI sitting on my bench. I'll give a review after I finish my surf boat
im lookin. too many choices. do they all except 4 degree bars?
I have only run UMI so I can't say how it compares to the others. But if you go with UMI, I would get the stainless berring from Jet Ski Solutions as well as the tuff thrust kit. I know its another $40 ontop of the other UMI stuff but it makes the system last much longer.
I have it and I like it. I have used UMI since 2002 and I have this for a short time but the quality is outstanding.WDK has the complete setup for like $209, bearing / mount / bar clamps / steering plate and bars $209.00 cant beat the price and it appears to be beefy, I have not used it yet, but I have touched it and fondled it some.
if your UMI comes loose just drill a hole through the stud and put a cotter pin through it. that will solve your problem, thats what i did and it works great.
seems like wdk is the way to go. ill see if he answers....
message machine is full......oh wll. probably be a week or two before my handpole is done anyway.
someone on pwc wants your sxr..bump up your ad
that wouldnt work on an ac square pole would it??i called jeff but no answer...
yesdo they have a website?
