I'm looking to buy a wetsuit for some spring and summer use. I would like one for water temps of about 50-60. What thickness should i get? What brands do you guys like?
The tighter the fit, the warmer you will be. If the suit is baggy on you
at all, that lets the water flow in and out and doesn't really help.
The whole concept behind a wetsuit is to let the water in, your body heats it,
and it acts as insulation. If new water keeps flowing in easily, it carries
away your body heat. Of course, this all depends on how much time
you spend in the water vs. up and riding on the ski.
So, if you can, try the suit on first. If it feels too tight out of the water,
it will probably be just right in the water. My own experience, anyway.
I have a Slippery Matrix suit that fits OK in the body but the legs are a bit loose. I use it all summer without the jacket more for protection than
warmth.
I have an O'Neill 3mm scuba diving john/jacket combo that I use
in the early spring and late fall. I have ridden in sub-50 air/sub-50
water with it and it was tolerable (I won't say I was warm, but I wasn't
freezing, either). The O'Neill is REALLY tight, but it keeps me REALLY warm.
