Hi Jay
Yes our hoods are made for Freestyle and yes they can handle it.
I'm not about to give away our laminiating schedual, however I will say that the use of core material is an important part of any structural Carbon Composite that has weight loss in mind. You did ask what the thickness of Carbon was, ours is measured differently to yours so you will have to work it out but 200g Carbon is approx 0.2mm thick. Just work out how thick you want it, this will then help determine the number of layers.
If you have never done Vacuum Bagging before you will need to buy alot of consumables i.e Sealent tape, release film, breather, Flash tape, bagging material, vacuum fitting for the bag not to mention vacuum pump.
Your mold also needs to be very high quality if there are any voids close to the surface you can be sure the pressure will find them. If you choose to bag on the flange you need to make sure the mold can take it.
You have chosen a very difficult first project, good luck and post your progress.
Regards
Chris
