FREERIDE Longbeach, WA 3/24-3/25
Phill
v Check out Little Matt_E
Kennewick, WA
We had skis in the water the water today!!! Ski is running great! Snackem didnt have much luck with that X2 though....:sneaky:
Crab
thanks darin...noswad!
Seattle
Do the wires on all X2's smoke?:sneaky:
Not normally, my neighbor pinched one on his TS when closing up the ebox last year, it fried the voltage regulator and melted all 5 wires going to the stator. The smoke was so bad we couldn't breath, it did the exact thing he described, ran for a couple then fizzzz.
Snackem
Danger Zone
Colfax WA
Let's not talk about pinched wires, Right now Matt thinks that it's his fault :sneaky: I'm not sure that it was a pinched wire however, the smoke was coming from under the pipe right by the stator. I also checked and double checked the box before I closed it to make sure that I had not pinched any wires. I could be wrong but . . .
The water on the snake was might cold but it was a BLAST, can't wait to get to the beach. . .
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
the gorilla boat (650sx) is ready to get salty wet.
i'm going out to lacamas sunday about 1pm for a tank.
that a big list of riders you got coming out !!!
gorilla
Crab
Seattle
Hansen? I doubt it, no bouy's out there. Partial list of who's showing, I will try and add names as needed.
Dan (me)
Nick (KgBsUkA)
Eric (TmcAuto)
Crab (Jeff)
GasGas (and rocky)
Swift
Mike B
Barry (Rasper)
Matt E
Snackem
Joe M.
Jonny
Monte
Charles
Larry
Chopper
Mike
Phil
Crashski
Dennis (DJB)
Sea-dude (Brian
Evan Boulanger, Tacoma (EvanB85)
Suva, and maybe 1-2 drag-alongs in.
Blowsion crew (invited)
Dan Coughlin (Hotolds442
Gorilla
Watcon gang?
Phill
Kennewick, WA
Thats a nice list! Randy at watcon said he and one or two drag alongs might show up too. The blowsion crew still wasnt sure if the would be able to make it.....busy time of the year....
EvanB85
Team Poseur
Tacoma, WA, USA
...finished the bilge pump install last night...
Re-wiring and new lights for the trailer tonight.
Quick and dirty footstrap install tuesday night.
Quick tuning/test ride wednesday night.
Packing and "The Addiction, AMCF3" marathon thursday night.
See y'all on Friday :Banane01:
sea-dude
To Air is Human
Man I am ever glad I water tested after mods! Installed primmer, flush, cleaned carb, 2 bilge pumps etc… So I took it to the lake and it ran like crap. I thought since I removed choke plate and screens out of stock F/A maybe I needed to rejet or turn out high speed screw. So after about an hour of screwing around I start to wonder why the top of my F/A is so wet…. Turns out the flush kit had a leak and was pissing water on top of F/A!
Plugged it and all is good.
Now I need to lake test the other blaster and I’m good to go.
Crab
Seattle
Lake tested my flywheel install this morning, and...:thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave: :thewave::thewave: :thewave::thewave::thewave: :thewave: :thewave:
:boggled:
You might say that. Hull has been float - tested, and spark plugs verified to be moisture resistant.:biggthumpup:
Crab
Seattle
And the scupper does wonders to help sink the boat at incredible speeds, especially when there are no bilge pumps.
Mine only leaks a little, sure keeps things dry when your moving!
