Start stop switch
The part with the nut on it should unscrew from the rest of the housing , inside you can probably clean the contacts with some fine sandpaper and contact cleaner and it will work again.
Yes I believe there is one so to make the button return.
I probably have some of that stuff laying around if you find yourself in need .
Ill let you know. Gonna try and find a carb spring or something to make it work. Gonna take the other side apart and see if I can find a match at a hardware store.
Looks like a carb spring
