- Asheville, NC
Thats no excuse, You have known about this for a year...............Either way, I’ll need the driveshaft for the conversion so hopefully this shaft makes it out alive.
@mrfist9 I don’t think I’m gonna make it down there this year, I’m scheduled for work but I’ll see what I can do!
just give us your bosses # we'll get it off for youAlright alright, I will do my best! Started a new job 3 months ago and it’s going really well. I should have asked off sooner, but hopefully I can get some coverage
New Job? DetailsAlright alright, I will do my best! Started a new job 3 months ago and it’s going really well. I should have asked off sooner, but hopefully I can get some coverage
I have had good luck with PB Blaster. Others you mentioned, waste of time. I have something a buddy gave me that smells like pine tar (Maybe its Kroil)..Two more things of note , most commercial penetrating oils I have used are garbage WD40 , PB Blaster, Liquid wrench , freeze off etc ,etc , the one standout exception is Kroil , I have recently seen it in places such as Advance auto , you can get it off of Amazon also of course.
If you don't want to wait though the next best thing is a 50/50 mixture of Acetone and ATF , it works like magic.
kROIL is professional grade stuff and up until a few tears ago was very hard to source locally . One other oil you don't hear a lot about anymore that is used as penetrating oil is wintergreen oil, it is the component in Marvel Mystery oil that give It that wonderful smell , but a lot of old tractor guys still use it to this day. It's wicking and wetting properties are supposed to be quite superior .I have had good luck with PB Blaster. Others you mentioned, waste of time. I have something a buddy gave me that smells like pine tar (Maybe its Kroil)..
Actually it’s a 122 stock. A 140 is a massive improvement.Look on the bright side, dump that pump and get the bigger 144, isn't that a 140 stock in there?
Was in shop last night getting ski's ready for SFF......... Looked up at my Lube Shelf and there it was. KROIL!kROIL is professional grade stuff and up until a few tears ago was very hard to source locally . One other oil you don't hear a lot about anymore that is used as penetrating oil is wintergreen oil, it is the component in Marvel Mystery oil that give It that wonderful smell , but a lot of old tractor guys still use it to this day. It's wicking and wetting properties are supposed to be quite superior .
You might be able to fit something like this off a Seadoo on it if you whittle on it a bit .
MSD Total loss master thread
Ok here goes I know there are some guys still running these setups, the info from MSD has mostly been lost and most of the links that you can find are now dead. So I am thinking it might be a good idea to create a master thread with any info that may be still floating around out there. I will...www.x-h2o.com
