Another Seized Impeller
This is actually my first encounter… heated with MAP gas and 3ft breaker bar. What do I do?! This is an FX-1 pump so I’m trying to salvage what I can. Unfortunately this impeller wasn’t bad before it spread out, just an old Skat-Trak 19-24 but take a look at my tool and the impeller… HELP!
Yep, it’s left hand thread like normal so I was pushing the correct direction for removal. Yeah I bet welding a large nut to it would be a good option! Unfortunately the inside of the impeller is pretty much stripped so I don’t know how much salvaging there will be :(
I had a wavejammer that ate rocks in a prior life, I took a skinny wheel and sliced it up to remove it from the shaft, but it was a soft aluminum one, might take quite a few wheels to get though that stainless one.
this is what i have done.
Sorry for the thread derail Brapp. If your goal is to salvage/reuse pump, shaft and prop I’d try taking a 5/8 threaded SS rod coupler ( outside flats 7/8) , bore the ID so it just slips over the shaft splines. Round off one end of it and slide the other end into the prop and weld it permanent. And give it a PB Blaster quench immediately after. At least you’ll have an external hex to work with that you can leave on the prop like the stock SJ props.
Well, it’s hard to explain why I needed to remove this prop but I wanted my FX-1 pump back that was currently in another ski and this was the pump for that other ski. I wanted the impeller for my pump so I had to take it off to make that happen haha Ideally I will be able to salvage the driveshaft and housing but we will just have to see! I guess when I get the impeller off we will see if it’s salvageable? I bet not lol
Otherwise I will just buy the @waxhead pump conversion for the FX-1 and be done with this lil’ fella
Yeah those 122 pumps are sleeping beasts! If they’re working leave em be, other than that , I wouldn’t waste much time on it. The juice isn’t worth the squeeze with 122’s…
The real issue is the way the impeller is designed you cannot get the heat where it needs it at , that and the fact that the Skat impeller tools are crap , how about a strap wrench around the whole impeller , another idea an old fan belt and a big ass wrench or a chain wrench with a piece of rubber between the chain and the impeller .
  • what-i-learned-today-with-jeff-smith-homemade-strap-wrench-2023-05-18_13-37-04_675629-1440x960.jpg
