About maybe... 2 rides into my latest iteration of my last B1. (Blursed) I determined that I had once again not built what I wanted. So like any ADHD ridden rider. For sale she want, sold she go.
I hadn't given up, basically every other B1 I ever ridden I absolutely adored. All that said, I wasn't really feinding for one, but kept my eyes out for a good deal. Specifically want a 96 twin carb. I have to date not had a dual 38 ski, wanted to see what it was all about.
Found my self Saturday morning Superjet shopping frankly cause I just need another b-pipe, stumbled upon this. Drove to Destin Sunday.
Figured worst case, I get a 61x/62t, sell the chamber, make it stock and send it on it's way.
Turns out it's super clean, rides amazing, and ah man I LOVE the thing. Doesn't really get me a loose bpipe (original goal) now does it.... IDIOT. Did nothing, put a whole tank through it, airbox flew off. Minor setbacks.
So now what. sigh another ski project just what we needed.
Gonna try and keep it simple. it's stock as a rock + a bpipe, really nothing crazy I've found so far.
Only things are a @JetManiac waterbox & a RIVA rear outlet. Which is nice.
Problems:
- weird idle transition... and idle. gonna go through carbs, got some fresh kits on the way, plans to jet it to FPP settings, hope it's already there with just a leaky N/S or something stupid.
- wear ring / impeller gap, gonna inspect and shim see what that gets me. Looks clean enough, but cavitates a bit when you do something stupid on it.
- fuel selectors bypassed.. normally I do this but on this I want a selector for SURE
Things I've already triaged
- tank check valve was blown out, replaced with a new
- missing small waterbox strap
- airbox flew off (2 of the 6 carb mounting holes are stripped lame)
- head pipe bolts 1 backed out, other 2 were loose as hell. All mismatched hardware. And ones helicoiled to M8
- steering shaft is tight, got it better but this won't matter
Mods planned:
- UMI (no particular reason why just a want)
- Bars probably
- Advance the stator a tiny bit (if it isn't already)
- play with nozzles & impellers
- intake grate maybe
- shaved head (wish this was easier to procure)
- reeds (if I find metal ones still)
Just want the thing to work! And work well!
Stoked regardless
Problems:
Mods planned:
- Bars probably
Stoked regardless
