The driveshaft failed last August 2024.
In August 2018, I had the housing rebuilt with my intermediate shaft. I did not recenter the pump drive shaft. I just assumed that if it was centered before, then it would stay centered with the new intermediate shaft bearing housing. I did grease the shaft. I also pumped some marine grease into the grease tube at that time. However, the grease tube is completely dry now and devoid of grease.
In 2020 I replaced the 650 6MB in it with a 701 61X and I eyeballed the alignment of the engine coupler with a straight edge. I did not use a feeler gauge the way the guys use it on youtube. But looking at my photos, I am not confident that I aligned it "perfectly." It is close, but not perfect. I will definitely align the new drive shaft perfectly.
Are aftermarket drive shafts and intermediate shafts as good or better than oem? Or do you guys recommend oem drive shafts and intermediate shafts?
Can I place the intermediate shaft into the intermediate bearing housing myself or should I have Jet Maniac do that?
I will know a little more after I pull the engine and remove the intermediate bearing housing and shaft.
I am definitely a rookie here, making rookie mistakes.
I will also inspect and grease the FX-1 and the 2019 SJ bearing housings.
