BA Freak (155 conversion) & carbon circus
With the circus, don’t use trim for anything but a setup wake. It’s a game changer. Even when doing combos, don’t touch the trim. The hulls design wants to do it all without any help. It’s so light and buoyant it’ll still flip weather you hit a wake early or late. The hull responds better to being more aggressive on approaches as well. I wish i could go back and ride my old one knowing what i know now.
DylanS
Gorilla Smasher
Lebanon Pa
Good info, thanks.
Yeah the thing comes around wicked fast with trim.
DylanS
Gorilla Smasher
Lebanon Pa
Made a few tweaks chasing an electrical bug.
Long story short, the on off switch for the brain poop the bed over night and left the ignition on until the battery died. Has happened before with no issues, but this time it put the old war pig to sleep for good. Shes seen multiple generations of riders and sat underwater for two years so it’s been a sad goodbye. For anyone wondering, YES it’s possible for the brain to get “weak” and fire weak and inconsistent spark on all channels. I’ve done tons of playing with these and tons of research and I personally have never heard nor had one die on me that wasn’t totally dead.
the ski would run solid for about 10 seconds then break up under load big time, but would idle fine on either cyl.
The first major giveaway to this would be the ski not firing off immediately like the total loss is known for, it was starting sluggish.
When testing on the bench the spark would start hot to the eye but you wouldn’t actually hear the crack and would quickly fade away under repetition on ALL channels, not just the two in use. The replacement is loud and strong as it should be. I’m not an electrical engineer but that pretty much confirms that the primary charge comes from the same coil? to all coil packs from all channels.
In my pursuit I found a channel wire on its way out for the 3rd time and had to molest my rad dudes cover again. Simply a bad, but cool, design right off the rip.
I might throw the example footage on YT for anyone perchance experiencing the same thing.
Looking for suggestions on some of the best water proof switches!!!
Its a shock it even worked at all being under water for almost 2 years haha. I believe the ms01 zeel is a replacement to the msd. So if everything else is still good, then that would be the best option
