- Vancouver, WA
Need some help before I go ahead and replace these carbs.
Im doing a pop off test on the rear carb of a dual 38 set up. Im getting an air leak between the carb body and fuel pump and yes im using oem gaskets.
I've sanded the mating surfaces, used a different fuel pump, replaced the gasket, tried mounting it up without the filter and o-ring thinking those could be holding it up but no success. I'm thinking it might be something to do with the Carb itself?
Can someone confirm this is the right stack of o-rings and gaskets? Any other suggestions before I get a new set of carbs?
