I have an old 440 that cranks forever (a couple minutes of on and off) before it slowly rumbles to life. Once it's running, it continues to run great. If I pour some premix straight down the carb it fires right up. I figured a quick fix would be to just install a primer and squirt some fuel straight into the carb every time to help it start faster. I Tee'd into the reserve pickup line coming from the tank (red hose in the picture) and ran that to a piston primer. For some reason I cannot get it to pull any fuel from the line. I pulled the hose off the piston primer and gave it a quick suck to see if fuel flowed freely and it did. I grabbed a known working piston primer and tried it with the same no fuel result.
I've installed primers before and had no problems but I'm stumped here. I'm using a quality made in USA piston primer, not Chinese. And a working primer from another ski still didn't make a difference. Does anyone know of something obvious I'm missing here?
