- Pennsylvania
I just got a full carbon phantom hull RTR minus engine, pump, trim.
I’m completely new to freestyle and just want to make sure I get everything ordered that I need. My donor ski is my 91 SN in need of a resto.
The power plant is a 61x with a protec rec head, protec black pipe, protec did port and polish work on the cylinders and the carb has a little work. IIRC its on .5 overbore.
I have list of stuff I need so far, but need some help from the experts as I want to do it all in a few garage sessions. Let me know if I’m missing anything.
Need:
155 Oem pump with SJ driveshaft
7/11 or 7/12 prop
RN mid shaft and housing
Trim setup (hull came with cable and lever)
My SN currently has the stock plastic waterbox, figured I should run a stock RN box.
Is there anything I’m missing? Thanks for any help!
Need:
7/11 or 7/12 prop
