- near beautiful bobcaygeon
A female flush connector came stock on my 2022 superjet (see first pic below with cap off) and similar is on an 2009 FZR.
I have a flush kit and you can see the male / connector adapter that plugs into the skis pictured below:
I am in the process of adding a flush capability to my '96 superjet and it would be convenient to be able to use the same water source side for all my skis. So, what i am after is the female side connector that could attached to a ski side diy flush hose setup.
It seems that at least for the SJ4 (I don't know about the FZR because it is in storage) the female - ski side - adapter is crimp connected to a hose that goes down to a splitter type part that looks to have barbed connections (which the manual calls a "joint") that feeds the oil cooler, exhaust, and cylinder block etc. So is is just the connector with a crimp connection to a short hose and the top part of this on the SJ4 is pictured below
This part would work great for my needs but my local dealer tells me that part has a 3 figure price tag (go figure) so buying new is out of the question for me.
Obviously I can make a diy ski side flush setup using garden hose type connectors, and this is how it will end up if no joy with OEM style, but since i have a shut off valve already configured with the source side setup that i already use for the other skis it would be nice to just use same on the '96 superjet too.
Does anyone know where i could get the ski side connector I am after at a more reasonable price? Maybe someone has a used one off an old ski I could buy from you?
