Wax surf Filter
waxhead
wannabe backflipper
gold coast
The Evolution of Airbox Systems for Mikuni Carbs​
Back in 2002, I decided to upgrade my ski with a pair of 44mm Mikuni carburetors. The additional power and improved throttle response were phenomenal, but the setup had a significant drawback: water ingestion. This challenge prompted me to develop a solution, leading to an innovative approach that addressed airflow and water resistance for high-performance carburetors.
Early Solutions: The Adapter Plate​
To mitigate water ingestion, I fabricated a plate that fit under the carb adapters. This plate allowed the use of flame arrestor adapters, effectively reducing water entry into the intake system by using the stock arrestor box. At the time, this wasn’t a common solution, but others in the community were experimenting with similar ideas. The system worked well with 38mm and 44mm carburetors, offering noticeable performance gains.
The Challenge with 46mm and Greater Carbs​
When transitioning to 46mm Mikunis, however, airflow issues became evident. Despite having ample airflow capacity through the flame arrestor’s 81mm intake hole—sufficient to service two 57mm carbs based on straight-line flow—performance suffered. The issue manifested as a rich condition, which could be adjusted by leaning out the mixture, but this introduced a new problem: reduced overall airflow.
Diagnosing the Airflow Restriction​
The restriction stemmed from how the flame arrestors were bolted to the plate. The adapters protruded into the intake hole of the stock arrestor, disrupting airflow. When we lifted the arrestor slightly, the problem disappeared, confirming that the interference was the culprit. All we had to do now was to figure out how to lift it and still have a decent way to clamp it and hold it together.
Developing the Clamp System​
To overcome this, we engineered a clamp system that eliminated the restriction while simplifying the installation process. The design allowed the flame arrestor to be removed with a single bolt in seconds. The carbs press against one side of the clamp, while the other side tightens securely without bending the aluminum components. This approach ensured durability and ease of use and has been running on our 8mm stroker lamey in the surf and in the river for 6 months with no issues at all.
With our system, the highest point was 115mm above the top of the ski hood line. We are using an FP1 hull with a lowered hood and have never had an issue with clearance. If you are running Novis, you will find they sit lower as the tops of the carbs are machined down to make them shorter. Knowing Novis carbs are machined and JB-welded at the adapter, we now supply a small bracing arm for added stability, available for an additional $20.
Performance Benefits of the Stock Filter​
Our system enabled the use of larger carbs, including 46mm Mikunis and above, with the stock filter, which remains unmatched for performance. The stock filter’s central air intake design is a key advantage. During aggressive maneuvers like end-over-end flips or rolls, water is forced to the periphery, while air remains concentrated at the center—where the intake is located. This ensures consistent airflow, even in challenging conditions.
Additionally, the stock filter operates as a still airbox. Unlike open intakes that are susceptible to turbulent airflow, the still airbox ensures smooth and consistent air delivery to the carburetors. This stability simplifies tuning, provides better debris and water protection, and enhances low-end torque. Reduced intake noise is another advantage, making the system more versatile for various riding environments. It also mitigates heat soak by maintaining cooler intake air, preserving engine efficiency and reliability.
Conclusion​
The clamp system revolutionized the use of flame arrestors with high-performance carburetors, addressing both airflow and water ingestion challenges. By allowing the use of the stock filter with larger carbs, it combined the best of both worlds: superior filtration and optimal airflow. This innovation underscores the importance of understanding airflow dynamics and adapting solutions to meet real-world performance needs.
There’s no shortage of solutions on the market, ranging from adequate to questionable. Some designs surprisingly reduce airflow compared to stock—an odd choice that makes you wonder about the priorities during development. After all, if you’re going to compromise airflow, why upgrade at all? Flat-water riders always opt for the largest carbs they can to achieve peak throttle response and power. It only makes sense to aim for the same high level of performance in the surf.
These are being made now and will retail for $125 USD including shipping from Wax Racing Products. If you want to get in early on the pre-buy and save $25 USD, now is your chance.
waxhead
wannabe backflipper
gold coast
Thats pretty slick. Ive always been a fan of the stock flame arrestor and its abilities to keep water out. Keeps the stock appearance when running aftermarket carbs too.
Good job
Thanks, Yeah im a big carb guy and when you are in the air and headed at the water with big carbs you know water is going to get in. its such a pain so i spent a lot if thought redesigning it. Nothing like the big carb hit and the stock filter water dispersion
Just got my adapter, looks great just a couple questions. What are the holes for in the bottom for, water drains? And the threaded ones in the side?
waxhead
wannabe backflipper
gold coast
yes the drains in the bottom are for any water that may get in there. The threaded holes are so you can make a bracket to support the filter on big novis etc where they simply jbweld the adaptor into the machined carb,
JetManiac
Stoked
orlando
So with std Mikuni 46 carbs, you put a/m f/a adapters on the carbs first and then bolt your plate to the adapters?
Like in your photo above?
waxhead
wannabe backflipper
gold coast
Absolutely. When installing larger carburetors, it's essential to use an aftermarket adapter to optimize airflow. While we could have designed it to bolt directly onto the top of the carburetor and attempted to blend it within a 10mm transition, the resulting blend angle would have been too extreme to provide any meaningful performance gains.
waxhead
wannabe backflipper
gold coast
Novi brace included ?
Not at this stage, but I do plan to in the future. The threaded section is there if you'd like to attach a brace. Some people prefer to run the pump out, while others opt for a jet block setup. Personally, I'm running it on Novis without a brace and it's performing well. I included the threaded point simply to give you the option to add support if you prefer.
Whenever we design a product, I always aim to make it as versatile as possible.
So I got mine installed on my JM 781 with a PHP manifold and 46's in my edge. Need a stubby allen wrench or a ratchet to get to the pinch bolt and a good bit of braille to find the bolt. The only thing I think that could be better is the surf adapter could have tabs on both ends for mounting the airbox, so that the pinch bolt could be on the inside (engine) or outside (hull) side. Otherwise super excited and can't wait to try this setup out.20250328_164300.jpg
waxhead
wannabe backflipper
gold coast
Wonder if it would flow enough air and would it work on 50mm carbs on a 1200 freestyle ski?
We designed it work with big carbs there should be more than enough flow on it. The inlet on the box is the same aera as two 63mm carbs and because we managed to keep it out of the flow path it should work just fine, The single airbox is also great for still air as it doesn't get the turbulence of a smaller system
waxhead
wannabe backflipper
gold coast
So I got mine installed on my JM 781 with a PHP manifold and 46's in my edge. Need a stubby allen wrench or a ratchet to get to the pinch bolt and a good bit of braille to find the bolt. The only thing I think that could be better is the surf adapter could have tabs on both ends for mounting the airbox, so that the pinch bolt could be on the inside (engine) or outside (hull) side. Otherwise super excited and can't wait to try this setup out.View attachment 455336
all good points. you can use a bolt on there so the head stays out of the recess. the issues i have with having the bolt on the other side would be the opposite side of the clamp would have to be a bolt on and i didnt want more parts to come loose, But i can think about it. Thanks for your feedback
Bay Area
Just purchased one from ShowtimeFreestyle! I cant wait to get it on! going in my edge with a TPE964. Already installed the bilge wiring kit and love that!
waxhead
wannabe backflipper
gold coast
My thoughts were to put these tabs View attachment 455337
back here
so you could flip the adapter and still mount the air box either way.
Hey, I just saw this—really appreciate you pointing it out. I'm always keen to hear feedback like this. It would allow the OEM top to be mounted the other way if you wanted to, and it’s a simple upgrade I’ll definitely look into for the new ones. Genuinely, thanks again.
