OEM style airboxes for 44/46 and aftermarket carbs
I've been working on this project for about 6 months now and feel like I've got something to offer the general public. What you're looking at is a clamp on and bolt on airbox bases that uses oem screens. The airbox top uses oem bolt spacing and has been redesigned to be lower profile and improve airflow into the carburetor. Base and tops are printed in petg. I found brass threaded inserts in both m5 and m6 that work wonderful with the plastic.
- The clamp on base angles the airbox top at 15 degrees and should clear all heads on stock stroke engines. 8mm+ would need clearance around the water ports as needed. I had access to dasa 49mm and ninja 50mm carbs and both had a clamp on diameter of 2.780". This is a tight dimension that would need to be checked for proper clamping force. The design can be modified for different diameter carb tops. If the clearance is too sloppy, overtightening of the clamp can crack the base. Pictured below is on an et967 with dasa 49mm carbs.
- The bolt on carb base angles the airbox top at 10 degrees and gives the same clearance as the clamp on base. Pictured below is a 61x cylinder with 8mm stroker plate. I found some knurled press-in brass "compression limiters" to get enough torque on the m6 screws without the chance of overtightening the base.
- the airbox top has a reduced profile to better fit most hulls. The rear is radiused and base profiled to the rubber screen to improve airflow. Flanged button head screws have excellent grip strength compared to using loose washers. The smallest cross sectional area of the inlet is about 40% larger than a 48mm carb.
I've been impressed with the strength and flexibility of petg and have tried to design these parts to reduce the chance of splitting from vibration. Smooth curves, fillets, and thick walls were used. I've broken a few covers on purpose to make sure I've got good layer adhesion. The bolt on base is quite simple and foolproof, whereas the clamp on base has the variable of different brand carbs having different diameter tops. If it were rubber and hose clamp it wouldn't be an issue. At some point I can have a database of sizes and be able to custom make them for the best fit. I can only assume the 2.780" is a standard but will vary from there.
As far as pricing goes, I've got about $24 total in materials for each complete airbox and feel $40 retail is reasonable. That will be the same or slightly cheaper than a used oem single airbox or pod style filter. $10 flat rate shipping. So for $90 you'll get two complete airboxes with screens and hardware shipped to your door. However, if you've already got the oem screens, I can take $10 off on each airbox. That's how much it cost me to bulk buy them and would rather save them for others that don't have them. I'm very interested in your criticism and possible adjustments before I begin printing. I've had a few local riders spend big bucks because of water intrusion and there is limited options when using aftermarket carbs. Hoping these will save some engines from early destruction.
IMG_20240204_180532305_HDR.jpgIMG_20240204_180547557_HDR.jpgIMG_20240106_125209957_HDR.jpgIMG_20240204_180344251_HDR.jpgIMG_20240204_180747643.jpgIMG_20240204_180807878.jpg
IMG_20240204_172207344_PORTRAIT.jpgIMG_20240204_172508387_HDR.jpgIMG_20240204_182654067_HDR.jpgIMG_20240204_183344929_HDR.jpg
Nothing back to back. The et967 ran all season on these and felt like the same power it had with pods. Building a flow bench has been something I've wanted to do though. I built an inertia dyno and loved playing with different variables. The butt dyno can only tell so much.
JetManiac
Stoked
orlando
butt dyno lol
Hello
Can I order a set? Wasn’t able to send you a private message.
Thank you
Although I've sold a dozen or so sets to people who wanted them, I'm seeing a larger variation in adapter diameters than I thought and has led to some cracking and failures of the bases. When the sizing is perfect they work great, but even a 0.25mm difference is enough to not make it work. I'm putting these on the backburner right now and want to see what I can do for some type of rubber hybrid setup.
Tpu is a very good filament for that. It's pretty inexpensive too. I've been using it for tires for rc airplanes I fly. Designed my own tire and rim. Used tpu for the tires ajd they hold up pretty well. I dont think it would be difficult at all to modify the base for a rubber coupler. Then design the coupler and print it with black tpu.
I haven't played with tpu yet, but I can believe it could be what I need to cover the range of adapter sizes out there. Moving to a captured hoseclamp would be nice so I don't need expensive m6 threaded inserts and the extra work invloved with that. I've had good success with the bolt on boxes. My own personal set has been through two seasons of surf without issue. One downside is the possibility of the bolts backing out and getting sucked in. I use liberal amounts of locktite when installing so that hasn't been an issue. What has been a big breakthrough was the addition of a "primer" paddle. I moved away from bulb primers and now can easily start within seconds with the paddle. It fits right in the airbox opening with the raised portion to self align. It's ziptied to my limiting strap bungie cord so it's always with the ski. Being the printed base has the same perimeter size as an oem single base, someone using just the cover top can also use the paddle for starting. For others that still use primers I added a bracket to one of the covers for internal hull priming.
New year, new design. The single pinch bolt is gone and now using a typical hose clamp. Twelve slots allowing for even clamping. Correct 3/8" wide clamps will arrive tomorrow. Now there's more flexibility in carburetor diameter, being able to clamp from 7.790" to 7.750". That was the biggest downfall to the single pinch bolt design, it had to be a very close fit so it couldn't be overtightened and break the base. Material cost is about the same, swapping the brass threaded insert and bolt for a single full stainless hose clamp. I've got a paint shaker at work that I could cobble something together for "stress testing" the new design.
