Zeeltronic 787rotax
Has anyone put a zeeltronic on a 787 as I was needing the ignition curve mapping
It’s for a zeeltronic o dis a02t
And has the spx 787 got a different map to a gsx and xp 800
beerdart
4-Tec Jetmate
CT
Yes many both A02 and 24 the 24 has 2 channel water injection built in.
dfw
For what compression, fuel, RPM, and carb setting? I cant tell you but I know they're easy to burn up.
So which wires on the zeeltronic a02t go to the pickup wires
I have the violet and green wires which say to go to pickup
On the motor plug end I have a black and a yellow/black coming from magneto
So I’ve programmed the zeeltronic but won’t stay running under 3000 and a poop to start
Can somebody tell me what the trigger type should be for a 787 is it
Single lobe
Twin lobe
Or one short and 2 long lobes
Also should the stop switch mode be on
Low level stop
High level stop
Or latching stop
This is what I have programmed now
Jcary85
Glenmoore pa
Single lobe
Twin lobe
Low level stop
High level stop
Or latching stop
Looking at pictures of the flywheel I see two lobes. It should be twin lobe. Stop configuration looks fine. There’s a very good manual for these that covers a lot of this information. I’d strongly suggest giving it a read.
