- Phoenix, AZ
I'm having an issue with my '91 SN 650 where it will randomly cut out completely, usually it will start right back up, but a couple times it has gone into a limp mode where the engine sounded fine but would bog at 1/2 throttle. Shut it off and let it sit, then it was fine. Richened it up just in case, and then a while later it died and wouldn't fire back up until it sat.
I've done a bunch of searching, and I'm now thinking that it's either my temp sensor or my gas tank venting. My main question is: will the temp sensor shut off the motor completely?
Any other insight as to the difference between these two symptoms would be appreciated.
