- Glenmoore pa
Hey all,
I'm still going through everything trying to find the cause here but curious if anyone has ever seen this. Ski has been running kinda crappy. feels like it loads up. If i keep it cleared out it makes decent power. Pulled head and all transfer ports on front cylinder are almost black. I assume its exhaust blowback but not sure. Rear cylinder transfers are clean aluminum. Went through carbs and everything looks good. Front plug is whiter vs rear cylinder. Motor has even compression. Reeds are all intact. Piston doesn't have a hole in it (checked with bore scope). I'm stumped.
This is a TPE 1200 with SE carbs and MSD ignition. I suspect ignition issue but who knows.
Curious if any 2 stroke experts know what causes this? Might help narrow my search.
