Starting a new project on my ‘91 square nose to swap my 650 with a 701 and I’m hoping to get out on the water by the 4th of July (or sooner). The 701 has a 62T case with a 61X top end. Looking for some advice and recommendations on the following:
• Should I keep my 6m6 flywheel, electronics, and stator, or replace with 62T components?
• Is the exhaust manifold a direct swap? Can I use my original 6m6 muffler?
• Does anyone have an intake manifold and/or a dual carb setup that they’re looking to part with? Are 38mm or 44mm dual carbs recommended?
• The stamp on the case is “65R”. Is this a 701 or a 780? How will this alter my build?
• I’m looking to upgrade to a Factory B and MSD enhancer in the future but want to focus on getting the ski running first.
• Open to any and all recommendations as this is my first engine swap.
I’m located in White Bear Lake, MN. Thanks in advance!
