On a brighter note, I finished turfing my tray and I'm really happy with how it came out!
The tray is wall to wall with 1" underpad plus an extra 1" at the rear which I shaped into a kick tail. I made a template using cardboard for the flat area painters tape for the compound curves.
After peeling up the tape and making relief cuts so it would lay flat, I traced it onto the turf and followed the outer radius ignoring the relief cuts.
I covered the sides and ffh with tape to protect them and then after pre-molding the turf around the kick tail, I practiced how to lay it down (without help) before applying glue.
I ended up doing it in two stages, because I just couldn't keep the "ears" and the rear from dropping and touching stuff as I tried to navigate the front edge under the foothold and the flaps into the side holds.
I think it turned out legit!
I still need to turf the rails as well as the back of the hood (Rickter style), and my chinpad, but I think I'm over my anxiety about turfing so hopefully I can knock them out before the long weekend.
