- Asheville, NC
Yeah, thickened epoxy with chopped strand and then lay some small strips of S-glass over the seam. That hood liner weighs nothing, it will be perfect. When the thickened epoxy really starts to flash, you can wet the tip of your finger with some fresh resin and use it to smooth the thickened blob. Be careful though, if you use too much resin on your finger, it will make the thickened epoxy start to run. Just a tiny dab of fresh resin on your finger will keep it from sticking to the flashed resin and allow you to blend it. I can get my thickened epoxy real smooth doing that. Plus, when you lay a small strip of S-glass over it, you can shape the blob a bit and get it to look nice and smooth!
Your build looks great though! You'll be flying upside-down and forgetting about that liner in no time
