Best 155 pump for a tpe 964???
I'm trying to get some insight on the 155 pumps. I'm rocking a 150 setback right now but I'm thinking about going to a 155 to be able to source impellers easier. Power plant is a 964 tpe with lowdown pipe. Any suggestions you guys??? Worth it to switch? Power increase? What size impeller to choose? I don't know impeller pitch In my current pump but it dose go faster than I like. I'm doing flat water only and looking to get the max bottom end punch.
Faster then you like? Not really sure what you are describing here. If Brian did the prop for it, it should be pretty spot on for a freestyle application. If not I would say pull the prop and send it to him to bend. He can tweak it.
I felt my 150 with my 964 made more bottom end then with a 155.
Faster then you like? Not really sure why you are describing here. If Brian did the prop for it, it should be pretty spot on for a freestyle application. If not I would say pull the prop and send it to him to bend. He can tweak it.
Good to know. I just like to be able source impellers elsewhere
