What are these plugs for and why is one pissing fuel?
yamanube This Is The Way Staff member Location Mandalor Jun 11, 2021 #1 What are these plugs for and why is one pissing fuel?
Snowmobiler Jun 12, 2021 #2 Looks like a Welch plug? Obviously it shouldn't be leaking. Sent from my SM-G970U using Tapatalk
yamanube This Is The Way Staff member Location Mandalor Jun 12, 2021 #3 Yes, welch plug. I gave her a couple love taps and it STFU.
JetWash Location Irish Hills, MI Jun 12, 2021 #4 Float was Stuck. Behind Plug is where its vented. Fuel pump just kept pumping her fuel till it came out vent.
yamanube This Is The Way Staff member Location Mandalor Jun 12, 2021 #5 JetWash said: Float was Stuck. Behind Plug is where its vented. Fuel pump just kept pumping her fuel till it came out vent. Click to expand... Float stuck open or shut?
yamanube This Is The Way Staff member Location Mandalor Jun 19, 2021 #7 It was running poorly and was lean on that cylinder. Leaking carb cylinder on the right, middle cylinder on the left. Attachments 20210611_172723.jpg 62.6 KB · Views: 3
JetWash Location Irish Hills, MI Jun 20, 2021 #8 The plug on the right looks more just washed with fuel from stuck float than actual lean. Youll know for sure when you get carbs open .
