Sealing the pump seal and pump inserts better fixed the cavitation and most of the water intrusion into the tray. About half a cup after 3/4 tank of riding..going to try to seal driveshaft tube from intake tunnel and see if that does anything..
Ski is super fun. I think I could ride similarly to mine if it had the same amount of power/thrust. It’s definitely looser in the apex of a turn but it slides controllably. Was able to get some good waves on it. Unfortunately I spider cracked the paint in pole bracket area manhandling it to hit a steep one..Was just where the stock plastic pole bracket cover was filled.. He was riding it really well..turning off the whitewater, on the open face and even did a little reentry..waves were small and steep and super shallow not the easiest to ride but he was looking really good on it. Definitely happy with it. I would actually like one with stock pump and pipe for small days..It forces you to ride differently when you can’t rely on being able to gas it and unweight/jump the ski out of the water at any time..have to ride smoother..the wide rails make it feel really stable but I can still lay it over..it’s super stable for him he can stand on it when he’s not moving but he was still putting it on a rail..he sanded all the paint off one tubbie from turning in 2” of water..
So final parts list for anyone interested is
62t/62t with stock 61x pipe, timing advanced and 760head gasket
Stock length pre 08 sj pole/steering cable and bracket moved the ball in and ground the sides of nozzle. Turns until it hits side of pump tunnel
Will probably get a lowered pole bracket for it
Wamiltons -1 turnplate on umi steering and 4deg umi bars
Cold fusion hood hook
Cold fusion throttle
RSKI hood straps. Buckle style but rated for 350lbs each
Cut down stock chinpad
Top air intakes on hood filled
Superjet tank with internal fill
Solas 17-23 cutback 2mm and modified stator section
Stock ride plate
R&D toploader intake grate
701 industries air box insert that raises intake so water can’t get in
OCD solutions tidy bilge kit and ocd toggle switch hidden behind 26mm padding on dash
Not a bilge pump fan and especially don’t like having to have it next to tank but I didn’t do a one way so it is as reliable as possible. Hate not being able to get all the water out of it though when I wash it. Engine compartment Stays dry as a bone when riding.
Stock hoodliner with Seadoo breather tubes with raised inlets so would have to have allot of water in hood to get into ski..
Jetmaniac limiting rope
Black waffle hydroturf
26mm padding on bottom of tray and dash..18mm on sides and 9mm on top of gunwales. Super plush and nice. Smooth turf on rails
Watcon hoodseal. Works great prob as good as oem..unfortunately the front of the hood is bowed so I had to turf the inside lip of hoodseal in front. Seals perfect.
ADA bow eyes/bilge outlets
Want to thank
@tomski for the fast shipping and midshaft build. His jetting recommendation was spot on..starts right up no primer needed. I almost put one on too..
@DangerBoy for the billet goodies and for the alignment jig..made it way easier..
@special fx for giving up a hard to find intake grate and hooking us up with a hoodliner and the chinpad
@JetManiac for all the good products In stock
@AAlamo for bringing the hull out from Texas
