61x 120 compression in both cylinders
As title says I'm getting low compression in both cylinders around 120 psi in my 61x engine . Is replacing Rings and Pistons my best bet? Any upgrades I might as well do during a rebuild?
If both gauges showed 150 last year and now the same gauges show 120 then obviously your compression is lower. If it still runs fine then run it. But at some point an engine is just simply worn out and can have low compression with both cylinders even and it's time for a rebuild.
How much does a typical rebuild run? 400$?
