- Downers Grove
I have wanted another full length swoopy sided superfreak since I first bought mine. Anyway I found one down in Texas and picked it up yesterday. Tem must have had a bunch of different bottom designs because this one is much more superjet like than mine. My original is a 2010 and is has the lowered pump with rocker. I knew from the pics that this 2009 didn`t have rocker, but it also doesn`t have the lowered pump. I have also heard that there were some, or at least 1 swoopy sided freak with a badass bottom, so there must be at least 3 different bottom designs that were used with the swoopy sides?
Anyway the parts pile and hull that I picked up has a lot more trick parts than I expected. At one point it was owned by a guy named Chance in amarillo Tx, but I don`t think he was the original owner as it has a 2009 FL homemade HIN. I knew it had a polaris genesis based 1085 engine with it. It also has a 12 vane 2" setback mag pump, the midshaft bearing was modified to run oil instead of grease. It has a Tem built carbon pole, and also a carbon turnplate. I`m wondering if this thing was setup to be a bouy race boat or just a really well built recreational boat. I can`t tell if it was ever assembled and run with this engine. There`s a whole bunch of custom parts to bolt this engine in, and some of them appear to have been run, but there`s no scuffing on the piston skirts so I don`t think this engine was ever started.
My original plan was to just toss a stock 701 in since these 1085 psi performance engines don`t seem to have a good reputation in the snowmobile world, but after looking over all the parts I kinda feel like I have to try it. Does anyone know the history of this ski? or if it was ever put together and ran with a polaris genesis engine? I bought it off of one of Chances friends son, who really didn`t know much about it. The ski appears to have started out with a metallic blue paint which was lightly painted over with gray paint. By seaching through some old posts I think that @txsuperjetfreak96 or @Yami-Rider may have known Chance or ridden with some of his friends.
