- Bemidji, MN
Ok, I'm pretty sure the water lines on a newly purchased 1100 swap are wrong.
All 3 lines from the head route to pissers.
It has a rad dudes modified front exit pipe that has a line going from the old inlet to new inlet. Seems like that would make it run way too hot. ??
RH line next to midshaft goes to bottom of header.
LH line next to midshaft goes to T.
T 1 goes to top of pipe.
T 2 goes to block under header.
RH hull line is plugged, im guessing this was the siphon line?
Any help would be awesome.
