First picture of 2021 Waverunner including Superjet
Quinc
Buy a Superjet
California
Dont forget to order your turbo kit! gain 175hp for only 9k. More power and less expensive then a new dasa or php!
https://www.kommanderind.com/Kommander/Turbo-Kits
was told you can remove the big rubber elbow and adapt a b-pipe too.
and man,those new BNG are to die for!
gonna need 3 msd enhancers though .....
that thing looks like it sucks the fun out of skying just like the sxr1500 did.
ItsRixter
SoCal Wav Jumping shiznit
Sunny Diego
Hey, I noticed that the EXR has a "HIGH OUTPUT" TR1 motor vs standard TR1 that is in all the other EX's and SJ4. What is the difference that makes a TR1 HO?
You know as soon as we find out, there will be the "HO mod" performed on SJ4's
My guess is the HO has a different tune and fuel injectors. Maybe just a tune.
West MI
Prior years waverunners had the HO and not as well (at least 2019 did), so although I don’t know the details of what’s different between HO and non-HO, I do know it’s not new.
EXR TR-1 H.O. has 10 more h.p. I read somewhere they bumped up the ECU.
Just curious. Are these the same skis?
My guess is that they probably are, and it is just the lighting that makes the first photo less angular. What do you think?
yup this is my biggest question. it seems like its most likely the same as the spark. its the same engine and a different tune. if we compare the stock spark is 60hp and is easily tuned to 110hp. im hopping the 100hp SJ can be tuned up to 130-135hp easily and safely. only time will tell.
Im hoping to straight pipe it, intake tune and wait for a impeller. i think that will really make up for the extra size and weight
