- seattle area, Wa
Hi all, I’m looking for some confirmation of a theory that my battery is bad.
Backstory:
This past weekend I was playing around on the sj jumping boat wakes all weekend. Launched off one, came down, lanyard popped out, ski dies.
Try to restart, no power. Very faint click from starter solenoid is all. End of weekend.
At this point I suspect that my ground cable broke, or something similar. Back at home I add a second ground cable and use a jump box to get the ski going. It immediately starts.
Next, I remove the “added” ground cable and use the jump box, ski starts immediately. So, my original ground cable is good.
I take the battery and place it on a battery-tender. After a little while it turns to green, indicating a full charge.
Ski will not start with just the battery, it needs the jump box to start. Jump box leads are connected to the battery cables and it starts perfectly. So, no cdi issues, no cable or grounding issues.
Next, I tried a test. Battery is removed from ski, jump box is connected to battery cables, and I start the ski. Then, I switch the jump box power to “off” and the ski immediately dies.
I had suspected that the stator voltage would keep the ski going after jump box power was disconnected, but this was not the case.
Additional info: I had the battery load-tested at a local battery supply store. At home the battery showed full charge on the tender. At the store it only read 8.3 volts and 34 cranking amps out of the rated 310 cranking amps.
Battery is a sealed Yuasa ytx20 battery new at the beginning of the season.
My question:
It seems obvious that the battery is bad based on its load test results. However, do I have another issue going on with the ski not being able to run on it’s own once the jump box power is disconnected?
I am not well-versed enough in the circuitry of these things to definitively say whether it should run on its own without a power source or not.
Is my stator or voltage regulator likely bad, or did I merely end up with a bad battery? I would like to hear some input before I go forward tearing into things I don’t need to be messing with.
The ski is question is a 2015 sj lites spec. It is stock engine, stock exhaust, stock carbs, running a 61x stator/flywheel and a msd enhancer.
Backstory:
My question:
