- San Diego, California
This is my first time rebuilding these carbs I got this superjet like 6 months ago and knew right away I was going to have to rebuild the carbs. The ski runs good except if I fall off or stop after riding for a minute I have a hard time starting it . but my question is when I rebuild them should I put all the settings back to stock ? Also I got the ski without the air filter mesh squair elements that cover the carbs under the black air filter cover. Should I get some new ones when I rebuild the carbs ? Or not even worry about it? I assume I need them if I'm going back to stock . another thing is I have an aftermarket fuel tank so I don't have a fuel shut off or reserve. Switch . and another thing is no choke. I have a primer knob with the choke butterflies removed. Other than that everything is stock that I know of untill I pull apart the carbs and see what seet and needle are in there and pop off spring . if u can think of any other tips or suggestions u think would be helpfull I'm all ears. Thanks in advance.
