701 61x sbt brand new overheating blown head gaskit
20200614_173304.jpgrebuilt 701 61x from sbt what would cause this every thing is new got looped holed because I had a pipe and jet it was overheating as soon as I drove it no water clogged anywhere new ware ring and prop 32/1 gas for brake in please help
Jcary85
Glenmoore pa
Assuming it actually overheated (the head temperature sensors do go bad FYI) I’d check your water line routing. Can you draw a quick sketch maybe?
The water coming out of the pisser would burn you and it would start to shoot out just steam after 3 4 minutes it was hot couldn't even touch it I'm really just stock on what else could be the problem because getting good water from the pump put something is off for sure and it doesn't overheat on the water hose when putting fresh water in it
It's a Riva red pipe the main line from the pump connect to the bottom of the manifold then there is a t with a line from the head to the pi to the fresh water clean out then there's a line that goes from one length of the pipe to the other with a 142 115 jet
Jcary85
Glenmoore pa
I’m not sure what the correct routing for that pipe is but it sounds like you have two feeds to the motor so water is just sitting in the motor.
Jcary85
Glenmoore pa
Actually maybe I misunderstood that. As long as water goes in the manifold and out the head it shouldn’t overheat
Every thing is the same as when I pulled the 701 out of it its something with the new sbt 701 I just don't know what yet I don't know if the jug was bad are the head but the gasket is burt and it gets hot way to fast but I am for sure that everything is right on the set up just something I've had like 5 other 701 guys look at it I just don't know where to go from here as to what to look into next also it had 160 160 before I pulled the head gasket
Quinc
Buy a Superjet
California
check your water lines. Did one come off at the pump? If you hook up your hose to the engine does it still over heat? Do you see water leaking? To test on a the hose: start engine, turn on water, turn off engine, turn off water.
That's a lot of rust on that head gasket for being brand new?
Yea I was thinking that I wasn't sure why that was there but the 701 was out for 3 days my question is what would make a head gasket burn like that after just a couple minutes of ride time
