- Asheville, NC
I'm very interested in how you got the pipe to fit!
I forgot to mention, I didn’t have to grind any more away from the hull. However I will say the the amount that I did grind away initially was necessary for the pipe to fit once I did get it in. The method I used for installing the pipe was
1: Installed the manifold on the engine
2: Installed the silicone coupler to the mid-pipe
3: Place both the chamber and mid-pipe into the hull
4: Place chamber into approximate location and then slide mid-pipe and coupler onto the chamber
5: Bolt the mid-pipe to exhaust manifold
