Thanks for taking the time to view. I like to work on my ski, but I’m relatively new to it. I bought an old 1990 sj that had a j700a 61x put into it(b pipe, and a few other bolt on mods). It was cavitating off of sharp turns so I ordered a new impeller. After removing the pump/driveshaft assembly to prep for its arrival, I noticed the wear on the splines. I’ll be ordering a new driveshaft, but i do not know which to get (pre 2007 I’m assuming). Also, I was wondering if this has happened due to the age, or is there something I should be looking for in the midshaft/alignment? Thank you in advance :cheers:
