WTB RRP cast pole bushing for rrp bracket
Have a cast rrp pole with Yamaha bushings, just upgraded to a rrp bracket andthe bushings are too wide. Looking for the bushings that work with the rrp cast pole and rrp bracket
Thanks
JetManiac
Stoked
orlando
RRP bushings in stock. As John said above, there are only 2 sizes for RRP poles with Yamaha setups, 1 for cast pole and 1 for billet poles.
assuming you have the correct bushings for a cast pole,there is no reason they would not fit.
as mentioned above,only 2 sizes i've seen are for cast or billet poles.
i've run into this problem once before and just turned the bushing down on the bracket ends so they would fit.
Turn the bushing down? Like rotate it? Or shave some off?
