After replacing all gaskets and did some body works I put back everything (the only thing replaced is the reed valve) which I put back the OEM with carbon reeds. when I run the ski it started then stopped after some trails it started but the RPM increases rapidly like a full throttle. I can stop the engine using the start/stop switch easily. Opened the carbs and cleaned the filters, jets and the in/out then tried again, the same thing happened but with a huge back fire. Tried to change the carbs tuning opening and closing the low speed needles, the same and the same.
760 engine
dual SBN 44's
B pipe
OEM manifold with OEM reed valves
TDR waterbox
All electric system is OEM
760 engine
dual SBN 44's
B pipe
TDR waterbox
