After coming back from the lake yesterday, I gave the ski a quick look to make sure everything had held up after my first ride of the season. I noticed there was a big gouge on the bottom of my hull (squarenose). It was not there last year, and I knew it did not happen on this ride. I'm guessing it's an old injury and the previous owner used a quick fix of some sort (see black colored filler). This looks to be about 1/4 inch deep, and you can see just how many layers are chipped away in the pictures.
1) How thick is the bottom of the hull? I can't see any damage in the inside of the engine compartment, but it must be close.
2) Is it best to grind anything away with a dremel before filling this in?
3) I don't want to pull the whole engine and everything - is it possible to repair working underneath the ski, or will gravity mess up everything I've done as it's hardening?
4) Are there any good, recommended fillers, or do I need to glass over this?
